zenith carb jet removal
mikeinWA
02-28-2004 10:48:46
I am in the process of rebuild on carb and finding it impossible to remove old jets. I seem to remember alot of posts regarding this procedure but a quick glance through the archives didnt help much. When is it time to get out the drill?
Slowpoke
03-09-2004 00:15:29
 Re: zenith carb jet removal in reply to mikeinWA, 02-28-2004 10:48:46
I would say never, unless the old one is damaged beyond repair. And where will you find a new one?
I don't think gas flowing thru a jet will enlarge it any measureable amount. Clean with solvent and if its plugged up, very gently use a drill bit of the correct size in the fingers, not a drill motor.
