1944 M Engine Rebuild
Larry in NY
02-28-2004 13:02:54
The engine is a 4" overbore with high compression pistons, firecrater? I am putting the engine back together and am in the process of installing new rings. I bought the Hastings kit. The original oil ring setup had a spring\oil limiter behind the ring. The Hasting kit did not come with one. Does anyone know if I should use the old spring or just use the parts that came in the kit?
Lee
02-28-2004 14:24:46
 Re: 1944 M Engine Rebuild in reply to Larry in NY, 02-28-2004 13:02:54
I would call hastings. If springs are required the kit should contain them. No used parts as far as the ring package.
Larry in NY
03-07-2004 16:59:02
 Re: Re: 1944 M Engine Rebuild in reply to Lee, 02-28-2004 14:24:46
Good call Lee, thanks! I contacted Hastings via the computer and they said their kit was all that is needed.
Resting easier in NY.
Larry
