674 Engine Balancer Timing (D239)
J.T. Britt
02-28-2004 15:15:06
The I&T manual states to locate No. 1 piston at TDC on the compression stroke.Locate mark on crank gear with the mark on the balancer gear.The only way i can get the marks on the crank gear at the bottom where i can see them is to put No. 2 piston at TDC.
Please help me.There must be something im doing wrong somewhere along the process.Thanks A-LOT.
JB
02-28-2004 15:41:08
 Re: 674 Engine Balancer Timing (D239) in reply to J.T. Britt, 02-28-2004 15:15:06
Hi, are you trying to time the injector pump ?
JB
J.T. Britt
02-28-2004 16:00:28
 Re: Re: 674 Engine Balancer Timing (D239) in reply to JB, 02-28-2004 15:41:08
No im trying to time the engine balancer.
JB
02-28-2004 16:17:18
 Re: Re: Re: 674 Engine Balancer Timing (D239) in reply to J.T. Britt, 02-28-2004 16:00:28
Sorry can't help you. Never had engine balance off my brother's 684.
Hope someone helps you.
JB
Bernard le mécano
02-28-2004 16:42:33
 Re: Re: Re: Re: 674 Engine Balancer Timing (D239) in reply to JB, 02-28-2004 16:17:18
Hi JB, put the 2 cylinder on TDC. You can see the timing mark on the balacer ring gear. Bernard le mécano Québec Canada
