IH two mold board plow
Farmall Ed
02-29-2004 06:21:28
I just bought an IH plow,and would like to hear from you all with any information you have. It has steel wheels,two lift levers,trip type clutch on the big wheel.It seems to be all there and in very good shape,no deep rust. Does any one know when they changed to rubber tires? I cant find a serial number on it,the beam part numbers are very visible. I plan to plow with it soon and will try to post some pictures.Any comments and info will be appreciated.Ed
Hugh MacKay
02-29-2004 07:29:48
 Re: IH two mold board plow in reply to Farmall Ed, 02-29-2004 06:21:28
Ed: I doubt that your plow ever had a serial number. I have owned 9 plows in my time most of them either bought new by myself, my dad or my neighbor. The only one I ever remember seeing a serial on was a 5x16 semi mount.
I don't believe there was any given date for rubber tires. They were optional for many years before they became standard. To give you some idea though, rubber tired plows were very rare maybe even non existant before WW#2, and by the mid 50s most of them were either mounted or on rubber.
On the model number if your plow has a lift linkage going to the rear tail wheel, and activated by the rotation of the rockshaft of the left front wheel, it is a Little Genius, probably a No. 8. If it has semi rigid tail wheel or no tail wheel with a long landside on the rear bottom it is a Little Wonder plow and probably No.3
Farmall Ed
02-29-2004 14:24:53
 Re: Re: IH two mold board plow in reply to Hugh MacKay, 02-29-2004 07:29:48
Thanks Hugh, I will post more as I learn more about it, and I try to get a picture or two on here soon. ED
