Installing starter switch. Wiring assistance pleas
Kurow
02-29-2004 12:18:02
Background
I have a farmall AV and have installed lights, gen etc. The starter i have is not original and has solenoid as opposed to pull lever. I have installed a "momentarily on" push switch to act as the starter switch. Question. How should this be wired up. Solenoid to one terminal and where should the other go?
Next question. How do i test that the generator is actually charging? When i have the lights on (tractor not running) it shows discharge which would seem right. When tractor is running the dial still shows discharge but the needle flicks every now and again. I have a meter. What terminals do i test aginest and what reading should i expect.
battery was fully charged when installed. Photo to follow of finished product.
Brad L
02-29-2004 12:30:25
 Re: Installing starter switch. Wiring assistance p in reply to Kurow, 02-29-2004 12:18:02
You would have 1 lead to your momentary switch that is hooked to the battery.The lead from the switch goes to one of the accuator leads on the solenoid and the other lead from the solenoid would go to ground + or - whichever grounding is yours
