'40 model Farmall H head rebuild
bill
02-29-2004 17:08:47
Who can I get to rebuild my head? How much can I expect to pay?
The tractor in question is very sound. The cylinder walls look great, so do the pistons. It didn't smoke when I parked it last July.
But after looking at the head, I'm thinking I should go ahead and have it rebuilt.
What do you think?
Thanks for your time.
bill
rustyfarmall
03-01-2004 08:19:31
 Re: '40 model Farmall H head rebuild in reply to bill, 02-29-2004 17:08:47
It would help if we knew where you are located, I know of at least 2 places in the southwest Iowa area that have a good reputation for quality work and reasonable prices.
Eric W
03-01-2004 07:25:25
I take my head work to the local auto parts store machine shop. Expect to pay a couple hundred dollars depending on what parts need replaced or just ground or if you get it milled.
Dave_Id
02-29-2004 17:15:05
You can certainly do a quick valve job, but don't be surprised if it starts sucking oil without doing the rings.
bill
03-01-2004 02:53:07
 Re: Re: '40 model Farmall H head rebuild in reply to Dave_Id, 02-29-2004 17:15:05
please explain.
riverbend
03-01-2004 07:19:19
 Re: Re: Re: '40 model Farmall H head rebuild in reply to bill, 03-01-2004 02:53:07
When the valves seal tighter, the rings are the next easiest place for the combustion pressure to leak. I think that the intake stroke might also suck some oil past the rings too. It has been a rule of thumb to do both valves and rings at the same time to avoid exposing the next weakest link.
bill
03-01-2004 12:00:26
 Re: Re: Re: Re: '40 model Farmall H head rebuild in reply to riverbend, 03-01-2004 07:19:19
so my options would be to do both, or do nothing? I'm trying to understand. it ran fine months ago, i'm thinking clean it up, reassemble. give input folks. thanks,
bill
riverbend
03-01-2004 16:46:36
 Re: Re: Re: Re: Re: '40 model Farmall H head rebui in reply to bill, 03-01-2004 12:00:26
You can do either, both, or nothing. Don't you love these clear cut answers ?
If you have the head off, put the plugs in and pour a little gas into the combustion chambers. If none leaks into the ports after a few minutes, you might not need valve work.
Doing a valve job without the rings might cause it to blow by the rings a little more, but won't really hurt anything. Oil is cheap. If it uses too much oil or smokes too much, put rings in it. I don't know if the head gasket is reusable.
As long as you are not laying in the mud to do it, and if there are no ridges at the tops of the sleeves, it is easy to put on another set of rings. These tractors were made to be easy to work on.
Mostly, it is remove the oil pan, unbolt the rods, and install new rings. The pistons will push right out. Be sure to keep the caps and rods together as sets (read the manual). If your oil pressure was good before, I would check the bearings with plastigage, but would not necessarily replace them.
