Super A block
VAJerry
02-29-2004 17:55:03
The block on my SA wich I've had for 6 or 7 years is cracked, was when I bought it and I knew. It has started leaking. The crack is behind the carb runs horizonal, about a foot long. When it was repaired last time it was welded. The beads seem to run along the surface more or less. My plan is to grind off the weld and either braze or JBWeld the crack. Any advice?
BIG JOHN
02-29-2004 18:19:33
 Re: Super A block in reply to VAJerry, 02-29-2004 17:55:03
Get after it. Many of us have tractors with a fix just as you are about to undertake.
GOOD LUCK
