Started yesterday ?
Warsaw
02-29-2004 18:47:48
Farmall H 6 volt Yesterday I ran it for 20 min or so showing my Dad my new tractor
He says to me better replace them corried cables so I went and bought new 4 gauge cable and stuck it on ,,,in the process the bolt in the starter came loose while getting the old rusted cable off
SO I put 2 nuts on there and tightend it up (the bottom nut pulls it tight)....anyway IT didnt want to start ,,,acted like it didnt have any juice ,,,and I thought I heard a spark..
My question is could I have moved the bolt in the starter to far up or down to prevent it from working properly?.
The other 2 cables are 6 gauge ...will this matter? I mean to replace them tomorrow
M guy
02-29-2004 20:39:58
 Re: Started yesterday ? in reply to Warsaw, 02-29-2004 18:47:48
What's happened here is you've twisted the conductor off the bolt that the cable connects to. Take it off and re-solder it or take it to the starter shop. Mguy.
Farmer Bob
02-29-2004 19:36:43
1st rule of thumb for good 6V operation:
Clean, bright and tight!
Get some "0" gauge cables also, those 4 and 6 gauge are a no-no on 6V systems. Make sure you have a good ground as well.
warsaw
03-02-2004 05:42:22
 Re: Re: Started yesterday ? in reply to Farmer Bob, 02-29-2004 19:36:43
Thanks alot ...Ill be taking it to a shop in the next few days This is the first 6 volt Ive had ,anything else I should be aware of ? DJ
