smta main jet threads leaking
paul
02-29-2004 19:11:33
I have overhauled my fair share of carbs and this ones got me. Completly dissasembled and soaked in agatator tank, after reassembly filled carb with gas to check float operation and leaks.So far so good,main jet needle seemed a little loose but no leaks.Of corse after installing on tractor and adjusting final settings,by the way ran like a swiss watch,a slight leak has appeared at threds not even enough to drip on the ground but it is driving me nuts.Please help.Loony bin.
Dan
02-29-2004 19:23:39
 Re: smta main jet threads leaking in reply to paul, 02-29-2004 19:11:33
Good luck. Had same problem with mine, got new jet and fitting, still leaked. Replaced packing with something I found around and doesn't leak. Also was sort of loose in threads before but is tight now. Think I jsut found some different type packing for it.
