farmall (H) engine overhaul pistons ?
Jonathan Mirgon
02-29-2004 19:51:18
I am wondering if I can order the steped head pistons for my 42" (h) or if I have to stay with the flat top pistons ?
justin
02-29-2004 21:25:14
 Re: farmall (H) engine overhaul pistons ? in reply to Jonathan Mirgon, 02-29-2004 19:51:18
What is the part number of the cylinder head on the tractor. The actual HP increase with stepped head pistons will actually depend on the tractor's cylinder head.
Jonathan Mirgon
03-01-2004 02:09:59
 Re: Re: farmall (H) engine overhaul pistons ? in reply to justin, 02-29-2004 21:25:14
it has the 8043d head, with 5 3/8 " valves
rustyfarmall
03-01-2004 04:33:22
 Re: Re: Re: farmall (H) engine overhaul pistons ? in reply to Jonathan Mirgon, 03-01-2004 02:09:59
I currently own an I-4 and an H which are both torn down. Both of these are equipped with the 8043 head, and the stepped head pistons. So yes, it should work for you.
