Super H Live Liftall
JEM
03-01-2004 12:05:30
I have a Super H with Live Liftall and loader.Lately the loader creeps down and doesn`t stay up unless it has a load on the bucket.I have resealed the loader`s lift cylinders;changed the hyd. oil. The loader has good lift power.Will this get better with more use? Is it hard to fix?
Aces
03-01-2004 12:46:07
 Re: Super H Live Liftall in reply to JEM, 03-01-2004 12:05:30
JEM don't think it will get better. That system has ball check valves to hold the load after you lift it. If it lifts ok the pump gears and pressure relief must be ok but the ball valves are not holding. You would have to take the unit out from the gas tank and pull the cover off and but new ball and seat in . Not a bad job.
