340 utility international ( gas) with torque amp
Glenn
10-18-1999 06:04:47
can anyone help ? need to know if there is a seal where the clutch peddal shaft is exiting the tractor body.I`m leaking oil & told by the dealer theres none If so what can be done?
thanks Glenn
Charlie V
10-18-1999 09:24:08
 Re: 340 utility international ( gas) with torque amp in reply to Glenn, 10-18-1999 06:04:47
There is a oil seal in the front of the trans around the drive shaft which could be bad, this would let fluid into the housing. Lots of work to replace it looks like. Only ones man guess but I bet it's the seal
