Super H decal help
Gauger
03-01-2004 18:25:15
I have a 54 Super H that's a dual fuel. There is a small decal on the right side of the clutch housing that is partially worn away. I'm hoping someone has a tractor with this decal intact and can tell me what it say's verbatim so I can have one made. It start's "Always close needle valve before switching from one fuel to another. When both valves are open at one time..... ." That's where it fades out. The font is all one size and the decal is approx. 3" wide by 1 1/2" tall.
Bill Smith
03-02-2004 10:44:08
 Re: Super H decal help in reply to Gauger, 03-01-2004 18:25:15
Should say something to the affect of when both valves are open at one time, fuel will blend or mix together (refering to the 2 different fuels, one type in each tank). You are no doubt just burning straight gas all the time I would presume. Information on this decal would be void if you are. Placement of this decal would be more for originality purposes. I would venture to guess you use the big tank for gas, and the reserve gas tank for a reserve if it is still present and functional. Originally the kerosene or distilate went into the big tank.
Mike ISW
03-02-2004 02:15:36
Go to www.batescorp.com They have the decal you need already made up.
gauger
03-02-2004 05:33:45
 Re: Re: Super H decal help in reply to Mike ISW, 03-02-2004 02:15:36
Thanks Mike!
Mike ISW
03-02-2004 14:30:07
 Re: Re: Re: Super H decal help in reply to gauger, 03-02-2004 05:33:45
Your Welcome :)
