Need help w/Select-trac / Select-a-valve Hydrolics
Pete in PA
03-02-2004 16:34:29
Hi all,
I'd like to install one of these select-a-valve units on my 1940 "H". Does any one here use one? What are they best used with? Any pictures of an installed unit would be helpful, or even detailed descriptions. Thanks in adavnce...
Pete in PA
Wardner
03-02-2004 20:47:02
 Re: Need help w/Select-trac / Select-a-valve Hydro in reply to Pete in PA, 03-02-2004 16:34:29
I have one on a '40 H. You don't see many of them. It splits one directional hydraulic power from Liftall into two separate single acting sources. It also has a middle gate for powering both power outlets at the same time.
I thought they might have been used on cultivators.
They are cast iron and most are broken.
Pete in PA
03-03-2004 14:54:16
 Re: Re: Need help w/Select-trac / Select-a-valve H in reply to Wardner, 03-02-2004 20:47:02
Hey Wardner!
Thanks for posting. I've also got a '40 H that I'm trying to put one on. You don't happen to have a picture of yours, do you? I sure would appreciate *any* information you could share about how specifically yours is hooked up...
Thanks!
Pete in PA
