Farmall 656 hyd ?
Wrenchbender
03-02-2004 17:12:56
What's the best way to hook in for power-beyond to run a loader valve? TIA, WB.
Gary
03-02-2004 18:31:44
 Re: Farmall 656 hyd ? in reply to Wrenchbender, 03-02-2004 17:12:56
Best way to do want you want is to run two hoses from your loader valve to one set of the hyd couplers on the rear of the tractor. Tie the tractor valve handle in the raise position. This will send oil to the loader valve. Just remember to untie the valve handle if you take the loader off. It could get real expensive to get a power beyond plate that you are talking about. You might have to change the outside hyd valve depending on if you outside valve is solid or has a cover on it. Want more info email me
