Order Farmall Cub Parts Online
Cub Hydraulics
D. Miller
03-02-2004 17:28:25
Is it possible to run a remote hydraulic cylinder from a cubs touch control system?
scruffy
03-03-2004 09:46:03
 Re: Cub Hydraulics in reply to D. Miller, 03-02-2004 17:28:25
There is a new one comes up on E-Bay every couple of weeks, sells for between 30 and $60.
I tried for one for my "A' last night and quit at $58, went for $59. It is a block of milled and tapped steel that fits between the metal hydralic lines and the touch control of your cub. It won't operate a remote hydralic system that requires a lot of fluid like a large cylinder. If you were going to attach a loader or similar you would require additional hyraulic fluid storage of some sort. The guy that sells them is making more for cub as we speak...
Bigdog
03-02-2004 18:01:51
Yes, but you'll need an auxillary hydraulic block in order to tap into the system.
Wardner
03-02-2004 20:55:21
 Re: Re: Cub Hydraulics in reply to Bigdog, 03-02-2004 18:01:51
I have one. I used it with a dump trailer. I can make you one or sell the block I have. Send email.
scruffy
03-03-2004 09:55:57
 Re: Re: Re: Cub Hydraulics in reply to Wardner , 03-02-2004 20:55:21
Wardner..Gee it sounds like a popular item, maybe you could make a business of these things,,
I am looking for one for my cub and "SA".E-mail me if you like..
I grow vegetables for a livin' and use all the old farmalls, I was given a hoeing unit that allows you to bring two hydrauliclly operated hoes togeter between your plants when scuffling.
Anyone ever use one of these things? I think they would make for a stressful day of cultivating! Thanks
Wardner
03-03-2004 11:22:11
 Re: Re: Re: Re: Cub Hydraulics in reply to scruffy, 03-03-2004 09:55:57
Scruffy,
The following is an email that I sent to the addressees below. I may have priced the block too high. I would be willing to knock off $10.
The block diverts 100% of the output. The Cub touch control can handle a large cylinder if it is double acting. The block was probably used on the one-arm Cub loader.
>To D. Miller and Chad.
>I only have one block. This puts me in the position of having to make one or listing the block on eBay. It will take me about three hours to reproduce and ship the block. The cost will be $75 and includes shipping. I have a Bridgeport miller so that is not a problem. I believe the genuine part is made from 3/4 steel plate. I would probably make the reproduction from 1" stock even though I probably have the 3/4" stock. There are approximately 7 or 8 holes on the face and one 1/4" NPT on an edge. The new piece could be made from aluminum for the same price. I can't remember if gaskets or O-rings are used to bolt it up. The pressurized fluid will have to go a small open center valve. It can be either 3-way (single acting) or 4-way (double acting). I still have the after market 4-way valve somewhere but don't know its condition. If it appears to be OK, I would let it go for $45. I might even get lucky and find the mounting plate that I made for the valve. No charge for that. I think it used the steering column flange and transmission cover bolts.
Wardner again
03-03-2004 12:01:49
 Re: Re: Re: Re: Re: Cub Hydraulics in reply to Wardner , 03-03-2004 11:22:11
Here is another email I sent to Chad.
If you send me a SASE, I will send you a rubbing (like a gravestone
rubbing) and include some dimensions. There are a total of nine holes.
One hole is blind and takes right angle to empty out the side. Thre are
four different hole sizes plus one threaded female NPT. It could be made in
a drill prress.
Wardner Randolph
1484 Andover St
Tewksbury, MA 01876
D.Miller
03-03-2004 05:35:11
Wardner,I would like to know more about the block that you have contact me at, metr
@shentel.net
Thanks D.Miller
chad
03-03-2004 04:44:46
i may want the block email me at cjpenny89@hotmail.com and let me know what you want for the block.
Chad
