484 Clutch Problem
Dale Kite
03-02-2004 20:23:13
We have a 484 IH that we bought new in 85, the first clutch went out in 3-96 at 1300 hrs.,second clutch in 1-01 at 2050 hrs., and now at 2300 hrs.This tractor does very little loader work and was used with a round baler for only a couple years. In 1-01 installed a rebuilt clutch and pressure plate and had flywheel resurfaced. The last two pressure plates had one of the fingers worn off while the others were barely worn.Also the throwout bearing was in pieces.Could someone explain why this keeps happening? Thanks for any and all help.
JB
03-02-2004 20:59:09
 Re: 484 Clutch Problem in reply to Dale Kite, 03-02-2004 20:23:13
Hi, is the return sring on clutch pedal broken ?
This spring is supposed to keep the clutch pedal pulled up so that the throwout bearing does not ride on the pressure plate fingers.
If the clutch pedal is adjusted properly and the return spring functioning the throwout bearing should not be touching the pressure plate fingers or turning when the pedal is not depressed. Also were you replacing the clutch with the HD 6 paddle clutch from a 684? My brother has a 454, 495 with 2250 loader and 684. We put the same HD clutch, presure plate and bearings in 454 and 495 as in the 684.
God luck
JB
