Order Farmall Cub Parts Online
Cub Transmission Question
Dan (nj)
03-03-2004 05:50:42
I have a 1951 Cub that I have to replace the main transmission shaft on. Now that I have it apart, I want to change the bearings. How do you get the rear bearing out? My I&T manual shows nothing. It looks like it has some sort of keeper on the differential side, but I can't seem to get it out. Any help is greatly appreciated. Spring is on the way and I need the tractor. Thanks in advance, Dan.
Rudi
03-03-2004 10:45:28
 Re: Cub Transmission Question in reply to Dan (nj), 03-03-2004 05:50:42
third party image
Dan:
Go to the link below - then to the Blue Ribbon Service Manuals -- those are the real deal -- IH Service Technician Publications.
Beats that I&T Manual hands down. I&T is useful for a few things, but definitely not a teardown of any type.
Hope this helps
49 Cubber!
03-03-2004 10:43:42
Upper or lower shaft?If i recall correctly,I just took a long rod and tapped it out.its been a few months and my memoty isnt up to par!
Dan (nj)
03-03-2004 12:17:48
 Re: Re: Cub Transmission Question in reply to 49 Cubber!, 03-03-2004 10:43:42
Cubber, it's the upper shaft. For some reason it won't just tap out. It looks like it should go back into the differential.
Dan (nj)
03-04-2004 06:54:45
 Re: Re: Re: Cub Transmission Question in reply to Dan (nj), 03-03-2004 12:17:48
Thanks to all, I got it out. It drives out back into the differential. It has a retainer back there to hold it in. Dan.
