IHC Seed plate question
Dieselrider
03-03-2004 14:53:16
I have a model 56 4 row corn planter and some extra plates with it. Some of the plates are original IH cast iron and the numbers are in the IH manual and one set is IH plastic and they are also listed in the manual. I also have two plates that are Lustran and have C-13 on them, and another set of Lustran with C697-24 on them. They fit the planter but the numbers are not in the IHC manual I have. Is there a cross reference somewhere that tells me what seeds they are for? Any help would be greatly appreciated. Thanks in advance.
Hayshaker5
03-03-2004 16:42:19
 Re: IHC Seed plate question in reply to Dieselrider, 03-03-2004 14:53:16
I work for a seed corn company and have access to a Lincoln Plate Reference Sheet. On any seed if it is plateable will have the suggested plastic plate on them. For example your C697-24 is generally used for a medium flat. On most seed companies bags it will be listed with the JD plate and then the IH (B6-C697). Your seed dealer should be able to provide you with the proper plates for the seed you have. I have that sheet at work and will try to get you one. Hope I didn't confuse you too much.
