farmall (h) carb distillate carb on gas engine ?
Jonathan Mirgon
03-03-2004 14:55:02
I am rebuilding the engineon my (h) after getting the carb # to order a rebuild kit I found that the carb # indicates that it is a distiallate carb, but the trctor is a gasser ? did Ih use the distillate carb on gas engines also ? or did some previous owner put the wrong carb on the tractor ?
Thanks in advance for your help !
Wayne Swenson
03-03-2004 20:31:56
 Re: farmall (h) carb distillate carb on gas engine in reply to Jonathan Mirgon, 03-03-2004 14:55:02
I just went through my son's "H" with distillate carb. The only difference between this one and a gasoline carb internally seems to be the idle air jet. The parts book lists one for gasoline and a different one for distillate.
The jets can be purchased at your Case-IH dealer for less than $20.
All I know and more.
03-03-2004 16:15:03
The carb should be OK one difference between gasoline and didtillate/kerosene was metering rod. Think gasoline carb tends to run a little leaner. Distillate/kerosene tractors were designed to run on gasoline until warmed up and 90% of them today are never run much longer than it takes to warm them up.
Meant to say.
03-03-2004 17:35:10
 Re: Re: farmall (h) carb distillate carb on gas en in reply to All I know and more., 03-03-2004 16:15:03
Metering nozzle.
rustyfarmall
03-03-2004 15:09:40
Your tractor most likely was a distillate burner originally. I don't think there is any major differances in the 2 carburetors, other than the fact that the distillate carb had a drain cock instead of a drain plug. My 1940 H has the distillate carb, and the rebuild kit I used for it was listed as just a Farmall H kit. You shouldn't have any problems using what you have.
Dave_Id
03-03-2004 15:08:22
My guess is they just started using gas full time, and the carb that is there will work fine on gas, no point in changing it.
