IH MD / TD engines
Dr Cy Kosis
03-03-2004 18:37:20
Does a IH TD9 share engines with another IH machine such as an MD or WD Farmall?
I found a TD9 right around the corner from me with a froze engine pretty cheap. The machine is in good condition besides being siezed. Two cylinders are siezed from rainwater in the stack for a few years. The head is already off and has been checked out, worked by a machine shop and is ready to go back on. I know it will need rings, pistons and liners for the two cylinders and a gasket set. Are these parts readily available and affordable enough to try to resurect this machine?
Red Rider
03-03-2004 19:50:44
 Re: IH MD / TD engines in reply to Dr Cy Kosis, 03-03-2004 18:37:20
Yes Doc the TD9 is the same as a WD9 334cu engine. I am not sure what year the TD9 went to the 350cu engine. Same engine as the 334 except 4 1/2 bore. The Super WD9 had the 350cu engine starting in 1953.
