Order Farmall Cub Parts Online
Starter generators on cub lo boy and cub cadet?
Tom Winn
03-03-2004 18:42:58
Does anyone know if a 12v starter generator from the cub cadet tractors will work on a cub lo boy 158? The cub cadet ones seem to be a lot easier to find, horsepower shouldn't be too different, thanks.
Kippster
03-03-2004 19:59:38
 Re: Starter generators on cub lo boy and cub cadet in reply to Tom Winn, 03-03-2004 18:42:58
The starter generator from a cub cadet tractor is 12 volt and unless your lo-boy has been converted to 12 volt, this will not work. If your machine has a 12 volt system, then that piece would work for a GENERATOR ONLY!!! You would use the factory starter to start the machine. The way a starter generator works, is when the electrical current flows through it in one direction, it acts as an electric motor, but when the direction of the electricity is reversed, then it acts as a generator. Hope this helps!!!! Best of luck. Kippster
Phlogiston
03-03-2004 18:58:56
Why don't you just have your old one rebuilt? Not a whole lot to go wrong with it.
Phlogiston
JSTPA
03-03-2004 20:42:18
 Re: Re: Starter generators on cub lo boy and cub c in reply to Phlogiston, 03-03-2004 18:58:56
Also a cub cadet starter generator is supposed to turn ccw, unlike most generators that turn cw.Plus they are alot more expensive then just a regular generator.I would fix your old one. jstpa
