460 head seepage
Paul
03-04-2004 16:52:21
Recently done complete overhaul. Having hard time sealing head. Doesn't appear to have any coolant in oil and runs fine.Should I have used thread sealer on head bolts? I don't think they go into the water jacket. Any other suggestions would be appreciated. Thanks, Paul
the tractor vet
03-05-2004 08:55:57
 Re: 460 head seepage in reply to Paul, 03-04-2004 16:52:21
I should have said something on this board a long time ago aboiut this so now is as goo as time as ever . I always use a BOTTOMING TAP to clean out the holes and also use either or brake clean to wash out the holes and blow dry and it does not hurt to ADD a couple of threads to the bottom but i have never had a head bolt bottom out on me yet , if it was a FEL PRO gskt . now i have had a hard time getting them to seal on the gassers and have since gone to the diesel toqure spec. on gassers this gets the job done.
RO
03-04-2004 18:15:09
Did you check the head bolts to make sure that they aren't too long and might be bottoming out in the block? I found that new ones I ordered from IH dealer were too close to being too long, that I went ahead and trimmed 1/8 inch or so off them. Someone on this board had suggested that even with new bolts, the fact that I'd had the head surface flattened might be enough to cause the new bolts to bottom out. I've since thought that that person gave me some very time-saving information. My 560D head is now torqued to spec and I know it's properly sealed.
Paul
03-04-2004 19:17:39
 Re: Re: 460 head seepage in reply to RO, 03-04-2004 18:15:09
Never thought of that RO. The head was shaved some and I may have to remove some length from the headbolts. Thanks
Stan
03-05-2004 05:24:31
 Re: Re: Re: 460 head seepage in reply to Paul, 03-04-2004 19:17:39
Paul,
How do you know your head isn't sealing? You say it runs fine with not coolant in the oil. I'm only asking because I had the head on my 460 shaved and didn't do anything to the head boltsto shorten them up. Maybe I need to
Stan
Paul
03-05-2004 11:05:18
 Re: Re: Re: Re: 460 head seepage in reply to Stan, 03-05-2004 05:24:31
When I run it for awhile, you can see a tiny bit of coolant foaming from out around the head gasket on the distributor side in a couple spots. After I shut the engine down, coolant will weep from around the gasket on the carb side after setting for a day. I'm not getting any puddles or big drips, just seepage. There is no white smoke from the exhaust.
