Rear crankshaft seal
CNKS
03-04-2004 19:25:54
Looked for this in the archives and got conflicting answers. On a Super H or similar, do you soak the felt seal in oil first or install dry? I just dipped mine in oil (no soak) and installed it. It leaks. The leak may be insignificant as far as oil loss, but it is more than I like. I've also read to install the two halves of the seal so that they don't match the two halves of the retainer (one end lower than the other). Is it possible that my present leak is not from the felt seal, but from the horizontal "rear oil seal retainer plate gasket" that extends into the oil pan. I could probably replace that without splitting the tractor -- again. Any suggestions for preventing leaks will be appreciated.
Aces
03-05-2004 05:25:26
 Re: Rear crankshaft seal in reply to CNKS, 03-04-2004 19:25:54
CNKS you don,t want to soak the delt defore you put it in the groove because it will grow on you and be harder to install. Soak after, but you leak could be where to to halfs go together because they like to warp. I never put new seal with out new aluminum parts because of this.
