Super A Power Steering
Terry
03-05-2004 16:13:26
I have been wondering..... Has anyone added a power steering set up to their Super A. I have a 53 A and I also toy with custom cars. This is a popular upgrade for cars and I thought surely some one could point me in the right direction on my A. Thanks in advance.
potosi
03-05-2004 16:37:17
 Re: Super A Power Steering in reply to Terry, 03-05-2004 16:13:26
Yes you can.I added it to a 140 which is the same.Use a Char-lynn hyd. motor in the steering shaft,cut the hyd. manifold lines,with hyd.hoses run the pressure line to a pressure regulator then into the hyd.motor,out of the motor and return to the pressure reg. then back to the return pipe of the hyd.manifold.I used iron pipe fittings brazed to the hyd.manifold.I know that I didnt make it very clear, however maybe it will help you. Lynn
Terry
03-07-2004 09:27:21
 Re: Re: Super A Power Steering in reply to potosi, 03-05-2004 16:37:17
I need some more details if you can spare them. This seems simpler but different than auto add ons. Please help!
