Ih 444 hydraulics
jim
03-06-2004 10:18:55
Manual hasn't arrived yet, Where is the fill point for the hydraulic system and how do you check the level
Jay
03-06-2004 11:03:12
 Re: Ih 444 hydraulics in reply to jim, 03-06-2004 10:18:55
The Fill & Level is on the main deck to the rear and right of the seat.
To check level, retract all cylinders and lower rock shaft arms. The oil should be at the bottom of the fill plug hole (not to bottom of fill plug).
jim
03-06-2004 11:19:40
 Re: Re: Ih 444 hydraulics in reply to Jay, 03-06-2004 11:03:12
It seems I may have air in system. Where do i bleed it from ?
Warm in Texas
03-06-2004 17:38:16
 Re: Re: Re: Ih 444 hydraulics in reply to jim, 03-06-2004 11:19:40
You don't. Just run it for a while with the cap off and the air will perk to the top as the pump circulates the oil.
