smta main jet packing
paul
03-06-2004 16:34:19
FYI.Just thought I would drop a line about aftermarket carb overhaul kits. The kits are a good product but the main jet packing is wrong.Put mine together and it leaked called I H dealer and he had one on the shelf worked perfect called my supplier and opened a can of woop a$$.Paul.
Van in AR
03-07-2004 06:37:06
 Re: smta main jet packing in reply to paul, 03-06-2004 16:34:19
Some of the kits from the manufactures do have the wrong packing in them, also if they are put in hot water before installing in the bore helps too. If they are old and hard in the box they will crack when compressed and will leak. A can of whoop a$$? A little harse since he didnt pack the kit.
Van
Dan
03-06-2004 20:34:54
Maybe that is why mine always leaked even when I changed main jet and part it screwed into. I finally used a small piece of small vacuum hose on mine I think.
Dan
03-06-2004 19:49:24
