460 Tach
Paul
03-06-2004 19:11:42
Just installed rebuilt tach from Williamson's along with new drive cable from Case/IH dealer. When reving engine to almost full throttle, RPM needle only shows about 700 RPM. If I use drill on distributor end of cable can get up to about rated RPM for drill. Drive gear appears OK and doesn't seem to slip if held with engine running. Any thoughts on this. Is the drive gear metal or plastic and are they still available? Thanks, Paul
paul
03-08-2004 09:14:09
 Re: 460 Tach in reply to Paul, 03-06-2004 19:11:42
One other thing. Does the ratio of the engine RPM to tach drive RPM from the distributor figure out to about a 3:1 ratio? May just need the tach recalibrated. Thanks, Paul
Gibby
03-07-2004 15:23:25
Plastic.... I was told they are tho available anymore. Email me I bought a spare one off Ebay by mistake.
Dave Gibson
