installing oil pump in 460 tractor
J Muehring
03-07-2004 11:45:31
Im reassembling the c221 for the 460 and was wondering how critical is oil pump installation / timing ? Is it best to follow I AND T manual or is their easier way ? Also when I put pump back together I used only one very thin gasket in gear housing cover. Will that help oil pressure ? Thanks very much.
K.B.
03-07-2004 17:09:58
 Re: installing oil pump in 460 tractor in reply to J Muehring, 03-07-2004 11:45:31
It is fairly critical that the oil pump be timed, because it drives the distributor. The method shown in the I&T manual is the way to do it, the actual IH manual would probably show the exact same picture. It's not hard to do.
J Muehring
03-08-2004 19:29:39
 Re: Re: installing oil pump in 460 tractor in reply to K.B., 03-07-2004 17:09:58
I put the crankshaft pulley on today so I will have timing marks to go by. I hope I got the pulley on far enough , it went really hard and yes I heated it. I didnt want to make it so hot it would melt the oil seal. Thanks.
