farmall 350
Dan
03-07-2004 13:09:04
My question is I would like to add power steering to this tractor and I wandering if all I need is the torque generator and hoses to plumb
into the live hyd or will it take more then this to have power steering ? Second question this tractor doesn't have a belt pulley asy I mean the whole housing isn't there.Will a asy from a h or m fit a farmall 350 Thanks Dan
Dave W V
03-08-2004 08:23:02
 Re: farmall 350 in reply to Dan, 03-07-2004 13:09:04
To do it like IH did the other things needed
are, pressure regulating and priority valve,control valve that was used for PS. steel line and fittings used to join the two,also a orffice plug. Belt pulley gear box will work ,engage lever
will be in a different dirrection though.
Charlie
03-07-2004 13:16:54
My Dad tried to move the belt pulley from a H and put it onto a 350 once and it didn't fit. I think it makes a difference if the tractor has a TA. His had one. I don't know if it would work on a tractor without a TA.
Hal
03-08-2004 04:25:10
 Re: Re: farmall 350 in reply to Charlie, 03-07-2004 13:16:54
My dad had a M tractor [don't know what year] and when the Farmall 400's came available after the war, as a veteraian, he was able to trade the M for the 400. It was the very first 400 sold in our county and I heard him say that they switched the belt pulley from his old M to the new 400. for what its worth!!!
