Super C Valve Cover Orientation
Bud
03-07-2004 19:19:31
The vent is off center on the Super C's valve cover . Can someone tell me if the offset is to the left or right as you look to the front of the tractor from the drivers seat. Mine is installed with the vent left of center and the breather is very close to rubbing the hood. Thanks
Haas
03-08-2004 05:51:11
 Re: Super C Valve Cover Orientation in reply to Bud, 03-07-2004 19:19:31
As Johan said, should fit only one way. I think the two mounting holes are also off center, so it can only go on one way.
bUD
03-08-2004 05:59:55
 Re: Re: Super C Valve Cover Orientation in reply to Haas, 03-08-2004 05:51:11
Once on can you tell me if the breather pipe is offset to the left or right of center of the cover? Mine is installed but for some reason the breather is not in the center of the hole in the hood. Thanks
Haas
03-08-2004 18:30:31
 Re: Re: Re: Super C Valve Cover Orientation in reply to bUD, 03-08-2004 05:59:55
I guess the only thing you can do is loosen the radiator mounts and try to slide the radiator over a little. This won't be easy, as the hoses are short and don't give much play to move the radiator.
Johan
03-08-2004 07:25:02
It depends a bit on how the hood is placed. You can maybe push the hood a bit to center the pipe. Try to turn the valve cover around and you find it will not fit.
Johan
03-08-2004 02:31:09
It should fit only one way.
