Pinion gear of starter
Kurow
03-08-2004 00:44:27
We have 3 starters to fit A, B etc and all of them have worn out the pinion drive gear. Where can i find a replacement before i go on a wild goose chase around New Zealand or spend lots getting a new one made.
Thanks
Hugh MacKay
03-08-2004 03:03:04
 Re: Pinion gear of starter in reply to Kurow, 03-08-2004 00:44:27
Kurow: Here in North America we could get those from CaseIH or just about any auto parts store. There are two types, the old Bendix with an exposed spring or a clutch centrifical type that I like much better. That is just a personal opinion, others will disagree. I find the newer clutch type engages more smoothly, easier on the gears and they just give a lot longer service.
Those old Bendix worked fine when the tractors were new. I have a gut feeling replacment Bendix are being manufactured by an after market supplier, that are just not getting it right. I had one new that wouldn't work either on my SA or 130. Finally I measured and it would just engage the ring gear by less than 1/16".
