RPM Question
Alpentom
03-08-2004 09:10:40
I just got the early 40's M that I recently picked up running this weekend and the RPM seems lower than my 0-6 with the same engine. I didn't measure it but from the sound and "feel" it doesn't sound like its running real hard at full throttle. The govenor did kick in at one point when I tried to goose it a little bit and let me know it didn't want to go faster.
CNKS
03-08-2004 18:34:56
 Re: RPM Question in reply to Alpentom, 03-08-2004 09:10:40
All "6" series engines, including the M, with the exception of a couple of the power units, are rated at 1450 rpm. As Rusty says your governor may need help, but could be out of adjustment. The service manual explains this. If you have different mufflers, the sound can fool you.
rustyfarmall
03-08-2004 10:43:14
Take a look at the rated RPM on the serial number tag, I think a W-6 is rated at a higher RPM. Also, the M governor may be worn enough so that it won't produce the RPMs. Might be time for some repairs and adjustments.
