414
Kevin
03-08-2004 18:14:49
Does anyone know what size the bore is in this block,not the sleeve size,just the bore size and how much can you take out.
Thanks.
Kevin
03-09-2004 06:18:57
 Re: 414 in reply to Kevin, 03-08-2004 18:14:49
EJ,
The reason I was asking,I hear you can put HD6 pistons in a 414 and get somewhere around 500c.i.
The pistons are allis chalmers,out of the HD6 dozer.
I"m not an expert by no means but it might be something to check into,you might not have to cut the allis slevees.
E J
03-08-2004 18:24:33
I plan on putting case 504 sleeves & pistons in mine to make a 540 motor useing a 466 crank. they tell me this will work.Cut some off the bottom of the sleeve and cut new oring grooves have not did any measurements yet.
