What does this serial number tell you
Kirk
03-08-2004 18:31:16
I just brought a 504 home today. The SN is 15941 S-X-7-FF. Can somebody look this up and tell me what the details are.
TIA,
Kirk
TDK
03-10-2004 19:54:25
 Re: What does this serial number tell you in reply to Kirk, 03-08-2004 18:31:16
Dave ID is correct on the FF & S codes. The X is High Speed Low & Reverse.I believe the Y code means Hyd. power Supply w/ 14 g.p.m. pump. I'm not positive on this one. I took for granted that your 7 was a Z, which means Hyd. Power Supply w/ 17 g.p.m. pump. I'll look tomorrow and post it here.Also, the ser.# says your 504 is a 1966 if it's an IH (utility) or a 1967 if it's a Farmall.
Dave_Id
03-08-2004 18:55:39
FF- Hydraulic Power Supply with 4.5 gpm pump
S- Ta with provision for 540 Independent PTO
X7- Not given in Guy Fayes Tractor Data Book. Are you sure it is a 7?
Kirk
03-08-2004 19:42:08
 Re: Re: What does this serial number tell you in reply to Dave_Id, 03-08-2004 18:55:39
It looked like a 7, but the data plate is a little hard to see behind the loader frame. I will check again tomorrow when it is light.
What are some of the possibilities that make sense?
TIA,
Kirk
Kirk
03-10-2004 19:07:14
 Re: Re: Re: What does this serial number tell you in reply to Kirk, 03-08-2004 19:42:08
OK, I was pretty busy yesterday and did not get a chance to look at the tractor.
The 7 was indeed wrong. I should have said Y.
The SN should be 15941 S-X-Y-FF
Thanks,
Kirk
BTW, what year is this machine?
