what does a three point hitch look like on a 504
john
03-10-2004 16:45:02
I am looking at buying a 1964 farmall 504. It has a hitch on the back which is controlled by two levers to the right of the seat. One of the levers says light..... ....heavy. I don't remember what the other says. Is this enough information to tell me what type of hitch it has and how hard it will be to find implements to attach to this hitch? thanks for any input. Also the hydraulics are very noisy, from what I read this appears to be somewhat normal? thanks
Joe
03-11-2004 14:11:21
 Re: what does a three point hitch look like on a 5 in reply to john, 03-10-2004 16:45:02
The Light-Heavy is your draft control lever. The other is your Raise-lower for the 3 point. Unless someone has changed it over to a fast hitch setup you can hook into any cat 1 and I think maybe cat 2, 3 point impliment.
As far as noisy hydrolics mine aren't all that noisy. Check the filters! Their is a good chance they may be plugged and starving the pump. Do the hydro's work alright? Or are they just noisy?
john
03-11-2004 15:15:07
 Re: Re: what does a three point hitch look like on in reply to Joe, 03-11-2004 14:11:21
Thanks for the info. What do they mean by draft?
The hydraulics seem to work fine, they are just noisy. If the pump is bad is it a big job to change it?
JD Kid
03-10-2004 18:08:29
have a Ih 504 but pretty sure there the same thing. ill get some pictures of the 3 point tomorrow and post them on here. email me if you want to see other pictures of it
JDKIA
03-10-2004 17:43:17
I have never had much experience with the "square front" farmall but the "light-heavy" lever sounds like a draft control lever, so I would say it has a 3-pt. but like I said I've never had any experience with the square fronts.
