Engine Size/Carb?
Boochie
03-10-2004 21:00:29
Fellows on my Super C---Need to get gasket set---that engine size is an 123 and not 113 correct?
Also my carb part # is 355 485 R91 dealer here has a new Zenith part #385 608 R91 is carb interchangeable (IWANT IT TO BE RIGHT)
Appreciate your help fellows
Thanx BOOCHIE
gene b
03-11-2004 04:34:01
 Re: Engine Size/Carb? in reply to Boochie, 03-10-2004 21:00:29
Is your carb a ZENITH or is it a CARTER. They are not the same gasketset but will bolt to the tractor ok.
Boochie
03-10-2004 21:26:15
Fellows found gasket set that say A,B,C and Super A up to serial #310299 but didn't mention Super C Will this work????? ?
Thanx BOOCHIE
Red Dave
03-11-2004 05:16:14
 Re: Re: Engine Size/Carb? in reply to Boochie, 03-10-2004 21:26:15
If it doesn't specify Super C, I would have to assume that it probably would not work.
You need to take your carburator off and clean the outside so you can read any tags or numbers that are on it. Take it along with you when you order the parts. Might save you from picking up the wrong thing.
Boochie
03-11-2004 06:41:31
 Re: Re: Re: Engine Size/Carb? in reply to Red Dave, 03-11-2004 05:16:14
Red Dave would this also be true for an engine gasket overhaul kit? Does the Super C use a 123 or 113 engine?
I do appreciate your help!!!
Thanx Boochie
Red Dave
03-11-2004 07:03:31
 Re: Re: Re: Re: Engine Size/Carb? in reply to Boochie, 03-11-2004 06:41:31
A Super C would have a 123 engine.
Look for the tractor serial number on the right-hand side of the toolbox under the seat. It should be 6 digits. Super C's serial numbers start at 100,000 and go up.
The engine serial number should be stamped on a raised boss on the right-hand side of the block, below #1 sparkplug, kind of behind the distributor. You should have both of those numbers with you when you go for parts.
If you haven't already, get an owners manual, a parts manual and a service manual. The best place on the web for manuals is Binder Books. I can't post a link here, but you can find it through google.
