farmall H gear patern
Kippster
03-10-2004 21:07:59
I just bought a 48 farmall H, and it shifts into all gears just fine, but unlike my friend's H which has the gear patern on the floorboard in raised numbers, mine has nothing. Can anyone give me a place to find the gear patern online or something?? Thanks a bunch!!! Kippster
Kippster
03-11-2004 16:29:56
 Re: farmall H gear patern in reply to Kippster, 03-10-2004 21:07:59
Thanks Guys!!! Now I have written it down on paper and plan on painting it onto the platform with white IH paint!! That way my wife won't run it through the side of the barn!!! I'm picking on her. I've done worse..... LOL Thanks again!!!
Chads
03-11-2004 07:59:37
I had a 9 speed H that had the top plate like your freinds, it did not have 5th gear, only 4 and reverse. It was a cable shift 9 speed. it was a 40, or 41 model. ChadS
F-Dean
03-11-2004 12:56:44
 Re: Re: farmall H gear patern in reply to Chads, 03-11-2004 07:59:37
No 5th probabaly means it came with steel. 5th gear was locked out for steel wheeled Hs and Ms.
Andy Martin
03-11-2004 19:00:47
 Re: Re: Re: farmall H gear patern in reply to F-Dean, 03-11-2004 12:56:44
And there is a long bolt under the left side of the fuel tank pedestal. You can remove that and put in a shorter bolt to unlock and use 5th. The gear is in there and will be new.
Don L C
03-11-2004 06:43:54
The Farmall H & M all have the same shift pattern..... ..... ..... ..
F-Dean
03-11-2004 06:04:54
Your friend must have a early H. The 39 and maybe 40 Hs had the shift pattern molded into the platform.
williamf
03-11-2004 05:03:48
The shift pattern is available on a decal, mine has one stuck on the light bar. My H came with all the decals, so I've never had to find any online, but they are available from a number of sources. (Do a search.) I don't know if they're available individually or only as a set, might vary by source. Good Luck
Wm
Daniel
03-10-2004 21:23:30
Are you looking for something like this?
Reverse Second Fourth
Neutral Neutral Nuetral
First Third Fifth (high)
sammy the RED
03-10-2004 21:21:49
The shift pattern of yours is the same as your friends.
JDKIA
03-11-2004 13:24:24
 Re: Re: farmall H gear patern in reply to sammy the RED, 03-10-2004 21:21:49
let's see if I can remember..... .
R 2 4 1 3 5
