IH H Model with Hydralics
Pat Irestone
03-11-2004 11:32:09
The hydralic lift on my old H is leaking oil from the lift piston. There is a collar with 4 bolts that holds the collar to the piston sleeve - but that is where it is leaking.
How do I fix that leak? Is there a gasket or some material I could use to seal the piston?
Hydraulic Rebuild Technit
03-11-2004 16:44:49
 Re: IH H Model with Hydralics in reply to Pat Irestone, 03-11-2004 11:32:09
If your hydraulic cylinder is leaking where the cap connects to the cylinder body itself and there are four LONG bolts that hold the unit together, then my assumption would be that the
O-ring in the cap which seals the main body of the cylinder is leaking. First, check the torque on all 4 bolts they should be exactly the same. If not, torque them all to about 45 lbs. test the cylinder. If it is still leaking, then you may want to consider replacing the o-ring. BE DARN SURE TO KEEP EVERYTHING PRISTINE CLEAN!!!!! Failing to keep everything clean will damage or will shorten the life of your hydraulic system. If you don't have the tools to replace the o-ring and keep everything clean, a new cylinder from Tractor Supply shouldn't be more than 30-40 dollars. Sorry to be so long winded. Kippster
