farmall m serial number quesitons
trent
03-11-2004 15:57:46
I bought this M no id tag under 1 hole say fbkm 140284 it has small feul tank and radiator shutters ????? any help is appreciated.
CNKS
03-12-2004 19:39:06
 Re: farmall m serial number quesitons in reply to trent, 03-11-2004 15:57:46
As Brooks said look for casting numbers, as they will give you the date the particualar part was made. All castings will have different dates on them, your tractor will have been assembled anywhere from a few days to a couple of months from the date of the latest one.
Brooks McCormick
03-12-2004 04:53:30
Go around to the right side(if you are standing behind the tractor) and look below the brake pedals, there is a stamp with a number then another number and a letter(ex: 7 5 Y)July 5, 1953. The stamp is attached to the tractor with 2 screws. This shows the date the tractor was built.
The letter is the year, Z is 1954, count backwards from there to get your year.
Hope this helps.
Allmost right
03-12-2004 17:48:59
 Re: Re: farmall m serial number quesitons in reply to Brooks McCormick, 03-12-2004 04:53:30
Both U and W were used in 1951 and V was skipped.
Dave_Id
03-11-2004 17:15:45
What is the question?
Trent
03-11-2004 19:27:18
 Re: Re: farmall m serial number quesitons in reply to Dave_Id, 03-11-2004 17:15:45
I geuss my question is what model m is it? and would it be an all feul model or diesel??
CNKS
03-11-2004 19:40:11
 Re: Re: Re: farmall m serial number quesitons in reply to Trent, 03-11-2004 19:27:18
It is not a diesel. It is either a kerosene or distillate model. The small tank is a starting tank for gasoline. When warm it was switched to the other fuel. These days it runs on gasoline only, unless you want to mess with kerosene, distillate is not available. Your tractor is somewhat unusual in that it still has all the parts -- don't toss them!
CNKS
03-11-2004 19:45:15
 Re: Re: Re: Re: farmall m serial number quesitons in reply to CNKS, 03-11-2004 19:40:11
By the way, your tractor is a late 1943, engine serial and chassis serial were the same until late 1945, so you can get a new reproduction serial tag if you want to.
Whoops
03-11-2004 19:50:23
 Re: Re: Re: Re: Re: farmall m serial number quesit in reply to CNKS, 03-11-2004 19:45:15
Your M is a 1947, I looked at the wrong page, I don't thing the engine serial is the same as the chassis serial -- sorry.
