Order Farmall Cub Parts Online
cub lo-boy 154 temp guage?
Tom Winn
03-11-2004 19:15:45
Is there anywhere to put a probe in the cub engine block to run a mechanical temp guage? any help would be appreciated.
BERMUDA KEN
03-12-2004 04:53:12
 Re: cub lo-boy 154 temp guage? in reply to Tom Winn, 03-11-2004 19:15:45
The 154-185-184's did not use an engine temp gauge. You can add one if you like. You will need to drill a hole in the lower engine water pipe to locate the sensor probe. This will give you an accurate engine temperature reading.
The Cub series are thermosyphon, so they tend to "self regulate" quite well. They also do not have thermostats.
