Paint without UV Protection
Needs advice
03-12-2004 08:34:48
I have a Farmall M, that is in excellent condition. All original. The paint only slightly faded. Since it is all original I do not want to repaint it.
The only thing missing is the grill insert. I have purchased a replica, and would like to paint it to match. Hoping that someone here can help me find some paint with out the UV fade inhibitors that are in most paints. That way I'd be able to paint it, and leave it in the sun for a year or two to fade it to match the tractor.
Any ideas?
Thanks!
Farmer Bob
03-12-2004 10:45:02
 Re: Paint without UV Protection in reply to Needs advice, 03-12-2004 08:34:48
You will no doubt have a problem getting the insert to fade to exactly the same color as the grille no matter what you do. If the M has the original paint as you said, it means that paint is at least 50 years old and has oxidized as well as faded over those years. Best to take the grille off and take it and your new insert to an automotive body shop and have them custom mix the paint to shoot the insert to match the grille. It will still fade but probably at a different time table than the rest of the tractor.
