How much for an M ??
todd
03-13-2004 14:33:28
I found an M farmall a while back and finally decided to ask the guy about it since it hasnt moved in a while. The motor is locked up he said it got hot because the fan belt broke. He then put on a new belt and it ran fine but was locked up after a few days. It has wide front power steering the front tires are good the rears are ok but real wether cheched. The tractor is in real good shape other than the motor and he wants $750 and wont budge off the price. Is that a fair frice or not. I thought I would offer $500 but he said no. The main reson I wanted it is for parts for my M like the wide front and powersteering. Would $750 be to much? todd
Nebraska Cowman
03-13-2004 18:08:53
 Re: How much for an M ?? in reply to todd, 03-13-2004 14:33:28
Todd, just where in western nebraska are you? I have a narrow fron M on ebay right now and the bid is stuck at $510 it is a running tractor with good tires.
allen Bishop
03-14-2004 19:49:07
 Re: Re: How much for an M ?? in reply to Nebraska Cowman, 03-13-2004 18:08:53
Hey!!! Nebraska Cowman!!! Shut the heck up!!!! I am the one that has the 510.00 bid o0n your M, HaHahahaHaHa Just kidding. Hope you get 10,000 out of it. I just opened it cause I wasn't going to let some wannabe get it from you for that. Good Luck and watch for me on ebay and here. I go by Harley1983, and I called you about where Wellfleet was on a tractor you had on awhile back. Take care and prosper, harley
todd
03-13-2004 18:50:19
I am by Chadron. What I was after was the wide front to put on the M I have. Mine has a narrow front with a loader. I thought I could pick this one pu for the parts.
Nebraska Cowman
03-14-2004 03:13:49
 Re: Re: Re: How much for an M ?? in reply to todd, 03-13-2004 18:50:19
a good wide front should be worth $500. I have a running M with wide front that I am going to sell I think. But the widefront has been welded.
AL-M
03-13-2004 18:04:22
It depends on location today I saw rough M motor blowing lot of blue smoke narrow front no PS but with Stage II SM hydraulic system and early type disk brakes (not SM type) no sale with good bid of $700. Wanted $1000. This was in Alabama.
Jonesy
03-13-2004 17:23:41
$750 is high for a stuck tractor but it has extras on it. WFE, possible live hyd, and PS. WFE go for about $500, ps $350 and live pump $300. Take what you need and part the rest out. It should pay for its self.
DuaneMN
03-13-2004 15:54:19
Todd -- If you are not interested at $750 we would be - we have Sheppard Diesel engine conversion that was built for the M in the early 60s - we have one M with it already installed but have another engine waiting for just the tractor you mentioned - does this tractor have live hydraulics?? We are in Minnesota - where are you located??
todd
03-13-2004 16:08:26
 Re: Re: How much for an M ?? in reply to DuaneMN, 03-13-2004 15:54:19
Duane this is a strait M it has a hyd. pump on the distributor and a belly pump. I have been trying to think of a good reason to pay the $750 but if I dont I will let you know. I am located in western nebr. There are several old M around the area but this one is only a few miles from home. I know of several just setting and have been that way for a long time. todd
don
03-13-2004 16:48:18
 Re: Re: Re: How much for an M ?? in reply to todd, 03-13-2004 16:08:26
Todd, if like you said the hydraulic pump is located at the distributor it is either a M&W add on or a Super M that is a Live Hydraulic system the belly pump is normally for the old front mount cultivators which was kept so people with the old style cults could put them on a real quick way to tell is if you have a battery box under the seat and it's 12 volts and the main front casting has two big eyelet bolt mountings for front mount cultivators on each side. I guess you need to establish what year it is to arrive at a price. Pictures would help.
CNKS
03-13-2004 19:09:30
 Re: Re: Re: Re: How much for an M ?? in reply to don, 03-13-2004 16:48:18
The live hyd on the SM/SH were not that much different than the belly pump, perhaps more pressure, but the main advantage was they were live. Hookups for the hyd on the cultivators should not have changed much. Yes the cultivator mounting on the front was a little different, doubt if that had much to do with the hydraulics, I don't know. Both systems were used for much more than just front mount cultivator's. My dad had a 47 H with a 3-disk semi-mounted plow (about the same plow slice width as a moldboard) that used the belly pump, it worked very well. Correct me if I'm wrong, but you said the belly pump was kept? The live hyd replaced the belly pump, the factory setup didn't have both. I suppose with an M&W with a separate reservoir you could have both systems. All letter series tractors were originally 6 volt, no matter where the battery was located.
todd
03-13-2004 17:40:05
My M is a 47 I think this one is about the same year. It has the battry under the gas tank and it is 6 volt. I am thinking pretty hard on buying it like you said the parts I need are spendy. I know of another M with a good motor but the steering gear up by the radiator came apart and he wants to get it out of his yard. M aybe I could put them to gether and make one out of two. todd
John A
03-13-2004 14:57:39
Todd, If The front end is good, and I mean damn good! Put Five hundred in $100 dollar bills in your shirt pocket. Another $125 in your jeans pocket. Go back an offer 500 cash, pull it out and fan the bills. See if he will bite on that! If not say you will split the difference with him. Cash Of coarse. He will bite then, only after he agrees to $625 do you pull out the remaining $125 dollars (Don't care on what denominations these bill are)
Do you really need the other parts off of this tractor, enough to justify the extra cost? Wide fronts can be had for an average price of about $500 or so.
Unless you cave too easyly, carry the remaining $125 also.
For me, this guy has to come some to me too for a deal to happen.
Hope this helps,
John A.
