Farmall 400 Diesel injection pump
Mike
03-13-2004 16:09:35
Hi, I need to replace the gaskets on the pump anything I should watch out for when I take it apart? Also Im gunna replace the front cover gaskets and seal on the engine. Is there much to getting the pump back in time? This is the first Farmall Diesel I have worked on. Tractor ran great just lots of oil leaks.
Randy in NE
03-15-2004 04:27:06
 Re: Farmall 400 Diesel injection pump in reply to Mike , 03-13-2004 16:09:35
There is going to be some timing marks on both the flywheel. This is like pulling the distributor. If you don't put it back together right then it isn't going to run. Depending on how far you are breaking down the pump you could be getting in for more than you want. If the pump is leaking it may be worth the money to have it rebuilt. Just my $0.02 worth.
