IH 2001 loader Will it fit a Super M??
Jonesy
03-13-2004 16:40:06
Ive got a chanche to get a IH 2001 loader for $1500. Is this a good price and will it fit a Super M?
Hugh MacKay
03-13-2004 17:30:55
 Re: IH 2001 loader Will it fit a Super M?? in reply to Jonesy, 03-13-2004 16:40:06
Jonesy: The 2001 loader will make a good loader for your Super M You will likely need to do some fabrication where it bolts to tractor. Some will try to tell you it depends whether it came from a Farmall or Utility. Yes in the parts book it will show differeny part numbers on sub frame for different tractors. The difference is just the actual mounting point, and fabrication will correct that. Over the years I have moved numerous loaders from row crop to utility tractors and vice versa. They aren't as different as most people would have you think.
On the $1,500. price tag; check for cracks on frame, wear in the pins and try and get the hydraulic rams extended, enableing you to see their condition.
