Ih 504 parts
TRactor Joe
03-14-2004 19:11:17
Looking to find a International 504 or 2504 for a parts tractor. I need sheet metel and other odds and ins.
Thanks,
Joe
tom
03-15-2004 04:13:57
 Re: Ih 504 parts in reply to TRactor Joe, 03-14-2004 19:11:17
i have the rear half of a 504 Farmall, and all new sheetmetal.
Joe
03-15-2004 08:02:38
 Re: Re: Ih 504 parts in reply to tom, 03-15-2004 04:13:57
Where are you located?
Puller504
03-15-2004 04:13:18
The IH 606 hood will not fit a 504 as the 606 hood is longer to cover the 6 cylinder engine. A 504 engine has 4 cylinders. Don
Wardner Randolph
03-15-2004 10:35:18
 Re: Re: Ih 504 parts in reply to Puller504, 03-15-2004 04:13:18
I am aware that that a 606 is a six cylinder. That info is right in the name of the model. The number of cylinders has nothing to do with the lenght of the hood. You need to look at the space between the water pump and radiator on a 504 to understand that there is alot of wasted space there. I would never categorically say that the two hoods are not the same lenght without using a tape measure. If someone is having a hard time locating a 504 hood, he should consider all options.
Puller504
03-15-2004 13:57:13
 Re: Re: Re: Ih 504 parts in reply to Wardner Randolph, 03-15-2004 10:35:18
Hmmmm, I'm sorry if I touched a nerve of some kind. I only pointed out that I know for a fact that the 606 and 504 hoods are not the same. It's not a goal of mine to anger anyone, just trying to share information. I have in fact fabricated some of my own sheet metal to replace missing/lost pieces from our tractors over the years. Don
Wardner
03-14-2004 20:56:26
Don't over look the 404 sheet metal. I believe it is the same. The CT Farm and Country catalog confirms this. I think that my spare 504 hood was lifted off a 404. It has been a few years.
606 also shares some of the same sheet metal. The 606 hood probably has exhaust and air cleaner holes in a different position from the 504.
