donor tractor starters
Kent
03-14-2004 20:09:24
I recently bought a basketcase 2544 and it took alot of amps to get the starter to turn the motor over. I decided to pull the engine for a rebuild and found the nose cone of the starter is broken off and someone tried to weld it back and the weld didn't hold. I was considering finding a starter from a tractor scrap yard. What models will fit this c-200 gas engine?? Thanks Kent
Haas
03-15-2004 06:20:08
 Re: donor tractor starters in reply to Kent, 03-14-2004 20:09:24
I have some NOS starter nose cones. Do you have a part number???
Kent
03-15-2004 08:37:16
 Re: Re: donor tractor starters in reply to Haas, 03-15-2004 06:20:08
Haas, I don't know the part #. I will look today and see if it has a number or call the dealership and post the part #. Thanks Kent
