IH 404/2404
Todd
03-15-2004 15:13:35
I have a IH 2404 that the 3-pt is not working correctly. When you start the tractor, the arms will raise. If you lower them while still running it will not raise them. Sometimes if you let them go ALL the way down it may lift them. I would appreciate any help.
Dennis
03-15-2004 17:57:23
 Re: IH 404/2404 in reply to Todd, 03-15-2004 15:13:35
My 300U was doing nearly the same thing. Turns out the control valve assembly was bad. I bought a used one from JP hargis and now mine works well. I am not very smart with hydraulics however and so hopefully other folks can give you more information.
