Super A Tie Rods
Bud
03-15-2004 16:44:42
Should the tie rods be of equal length after adjusting for toe-in? Thanks
SAm in NS
03-16-2004 06:29:05
 Re: Super A Tie Rods in reply to Bud, 03-15-2004 16:44:42
They should be the same but only if your front axle is extended the same amount on each side. I've seen a few where especially the left hand side is extended further than the right hand side. Also if your tie rods are bent or if any of the other links differ in alignment from side to side. Hope this helps. SAm in NS
Hugh MacKay
03-15-2004 17:56:20
Bud: In theory I supose they should be, however that is precisely why you have adjustment, to make corrections. If they are far off from being same length you will find tractor will turn sharper one way than the other.
Kevin in Va
03-15-2004 17:12:41
Looked in the I&T Shop Service Manual IH-8 which covers the Super A. No mention of toe in adjustment. Sorry.
