544 starter help from previous post
Kent
03-15-2004 18:47:50
Haas and anyone who can lend me a hand, I went to my local NAPA and he couldn't find a starter to fit. He called the help desk and so far they were no help. The number on the starter motor is 1166770 or 1108770 the best I can make out.The starter is a Delco. The nose cone says D-3605 with a R in an oval above the number and K2 below the number. The I&T manual for 544,2544,656,2656 shows the following numbers:
1107744 65-100amps 3600-5100rpm
1107543 75-100amps 6470-8750rpm
1107854 50-80amps 5500-9000rpm
1108344 53-69amps 6400-8600rpm
1113187 50-70amps 3500-5500rpm
1113198 50-70amps 3500-5500rpm
1113201 50-70amps 3500-5500rpm
The manual doesn't tell which numbers fit what model and engine. Does anyone know which part# fits the C-200 gas engine?? Or possibly the Napa part #?? Thanks Kent
K-Mo
03-16-2004 05:01:55
 Re: 544 starter help from previous post in reply to Kent, 03-15-2004 18:47:50
My book says the 544 Gas uses starter No.
1108344 for Gear Drive
1107854 For Hydro Drive
Good Luck,
K-Mo
Bruce Wa.
03-15-2004 20:36:25
I have a hydro 544 wiyh a 200 gas. I could probably get the no. off of it tomorrow . too dark now.
